remove turbine housing
Posted by Jungy, Nov 13, 2006
420A Bolt-on Tech - Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum.
Please Support Jackson Auto Machine
  1. Jungy
    Jungy Proven Member
    DSM Profiles:
    Nov 2, 2006
    94
    Saint Cloud, Minnesota
    Crazy_Skier and i are rebuilding his 50 trim t3/t4 and we've run into a prob...No matter how hard we try we cannot get his turbine housing off. We've been hitting it with a rubber mallet and no luck, so we started in with the liquid wrench and the rubber mallet and still no luck. I'm gunna try using the torch on it later, but what i'm wondering has anyone had this prob before? and do you have any tricks to getting it off? Thanks in advance!
    #1
  2. WMD
    WMD Proven Member
    Nov 9, 2005
    222
    7
    Verona, Wisconsin
    LOL I remember trying to get the compressor housing off of a mitsu turbo. It uses a giant spring clip, and my lord is it hard to get off, even with the right tool. LOL
    I think you should take off the compressor housing and then put it in a 500*F oven. It might be safer than putting a consentrated 2500*F flame on the housing.
    #2
  3. BigRand
    BigRand Proven Member
    DSM Profiles:
    Nov 17, 2004
    1,818
    30
    Toronto, Ontario_Canada
    Just spray it down with some stuff to loosen it up and wait.....try it every once in a while, but it'll just happen on its own. Becareful not to strip any of the turbine housing holes otherwise you'll be retapping them as well.
    #3
  4. Locke
    Locke N/T DSM Wiseman
    DSM Profiles:
    Jan 1, 2005
    2,683
    12
    Houston, Texas
    A turbine housing can handle plenty of heat. as long as he doesnt use a cutting tip on the torch..
    If you have any experience with a torch, other than cutting, use oxyacetylene and a tulip tip. MAPP gas will probably work also.
    Also, you may find a dead-blow hammer extremely usefull.
    #4
  5. Jungy
    Jungy Proven Member
    DSM Profiles:
    Nov 2, 2006
    94
    So last night we sprayed the crap outta it with the liquid wrench and hit it with a rubber mallett, still no luck on getting it to move. So it would be ok for us to use the torch on it ? I'll give it a shot later this afternoon.
    #5
  6. Locke
    DSM Profiles:
    Jan 1, 2005
    2,683
    12
    Houston, Texas
    yes, heat is fine. Just dont use a cutting tip, and you'd be amazed how much help a dead-blow is.
    #6
  7. Jungy
    Jungy Proven Member
    DSM Profiles:
    Nov 2, 2006
    94
    ok well i'm gunna go find a dead-blow hammer then! what ever it takes to get this off...haha
    #7
  8. WMD
    WMD Proven Member
    Nov 9, 2005
    222
    7
    Verona, Wisconsin
    The turbin housing would most likely see a max egt of 1600*F. This heat would be dispursed over a large, even area. While im not saying it cant handle more, im saying you'll reduce the chance of it cracking if you put it in an oven or something of that nature. Because when cast iron is unevenly heated, it can cause it to warp and crack. Thats why I would advise you not to use a torch. Cast iron is pretty picky about thermal expansion.
    Take your time, it will come off.
    #8
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
