Please Support STM Tuned
420A Rebuilding 420A-T
Inkdlyfe
438
7
Feb 23, 2016
Summer feild, Florida
Alright so finally got my last part to my rebuild new everything period but i came across something im not sure of totally. Alright so i do have arp head bolts only been removed once but i have oem bed bolts where the cranks held in they also only been removed once can i reuse the bottom bed bolts or no??? I know arp is better to go with but i dont have the spare money right now for them. Another question the new rings i got seem to fit very tight but are the same .50 i removed even matched them up to make sure. Should i continue putting them in or.
Any other key point to a re build i should keep in mind ?
I have reused the bed plate bolts multiple times and never had a problem. I mean re use the same set on every rebuild or block . So every rebuilt or built block that has gone in my car is using my original bed plate bolts.
I know I should have replaced them but anyways.
If you get a new set of OEM bed plate bolts youll be solid.
