Rear tires bigger than my front!
Posted by jibberishballr, May 22, 2006
Please Support Ace Race Parts
  1. jibberishballr
    jibberishballr Proven Member
    458
    3
    Joined Aug 23, 2005
    Chico, California
    Like the title says...So i was wondering if this would cause any problems suspension wise or anything else? I noticed when my friend pulled his gs-t up next to mine. His is all stock and i thought he had lowered it because mine looked further off the ground than his...LOL
    Log in/Register to remove ads
  2. blcknspo0ln
    blcknspo0ln DSM Wiseman
    5,435
    75
    Joined Jul 31, 2003
    Central, New Jersey
    Not if you're FWD. As long as the driver and passenger side tires are the same.
    My DSM:
    1995 Eagle Talon TSi AWD
    12.030 @ 118.070 MPH
    Loading...
  3. nightspeed87
    nightspeed87 Proven Member
    1,732
    9
    Joined May 2, 2006
    Tampa, Florida
    are you talking about wit stock rims also, or aftermarket because theres a lot of different things that will evaulate this, when i tried this on my stock rims i put bigger in the back, i think it was 215/45/16 and the stock 205/45/16 i believe it had poor handling and the car felt like it wanted to slide off the rode when i turned hard, so i ditched that set up and just put the bigger size of the back tires all the way around and have it lowered 2in . Oh anbd i forgot the handling sucked with that bigger in back set up dispite that i have front and rear strut bar, so i wouldnt recommend it unless its aftermarket rims. I have a friend with 225/40/16 in the back on his stock rims and the regular size tires on front and his looks mean as hell sitting like that, but i dont think it did any justice for his handling either. that set up is more for drag racing but if you like slamming corners i wouldnt recommend it
    My DSM:
    Loading...
  4. nightspeed87
    1,732
    9
    Joined May 2, 2006
    Tampa, Florida
    but mines is a first gen also if that makes any difference...
    My DSM:
    Loading...
  5. blcknspo0ln
    5,435
    75
    Joined Jul 31, 2003
    Central, New Jersey
    I suppose I should have ellaborated on my answer. The question is NO you will not "hurt anything" by running a staggered wheel setup. Do you want to? depends on the situation like the above poster mentioned.
    My DSM:
    Loading...
  6. jibberishballr
    458
    3
    Joined Aug 23, 2005
    Chico, California
    I just think it doesnt look as good...I like how my friends looks with tires of the same size
  7. jibberishballr
    458
    3
    Joined Aug 23, 2005
    Chico, California
    Its aftermarket rims too by the way. I think im going to get tires of the same size and see if it looks better. I hope it does.
  8. blcknspo0ln
    5,435
    75
    Joined Jul 31, 2003
    Central, New Jersey
    Of course running the same tire on all four corners looks better, silly. :tease:
    My DSM:
    Loading...
  9. Matchbox
    Matchbox Proven Member
    15
    Joined Oct 18, 2003
    , Asia
    If you have ABS, it would not funtional correctly when any one of wheels is not the same as others. :dsm:
    My DSM:
    Loading...
  10. nightspeed87
    1,732
    9
    Joined May 2, 2006
    Tampa, Florida
    that could be true... You could risk it if you really like the way it looks that way but i know you wouldnt want to go back and forth spending money trying to figure out which size is the best size so i guess just keep doing your research.
    My DSM:
    Loading...
  11. jibberishballr
    458
    3
    Joined Aug 23, 2005
    Chico, California
    I must not have ABS then because it works right now and ive got different size tires on. I think im going to get smaller tires for my rear so it looks lower and much better IMO.
  12. b-nizzzle
    b-nizzzle Probationary Member
    18
    Joined Apr 29, 2006
    Chico, California
    ya u should get new tires in the back.. the whole bigger back tire setup looks wird when the front of your car is goin downward.. i bet ## friends car looks way tighter :p :p JK
  13. elfroggo
    elfroggo Proven Member
    348
    6
    Joined Mar 30, 2006
    Palo Alto, California
    Well, you only use ABS when you brake hard enough to lock up the brakes then the computer takes over. So in normal driving, yeah your car "works".
  14. Matchbox
    15
    Joined Oct 18, 2003
    , Asia
    There is two ways to check if you have ABS or not. (a) open your hood and ABS module locates behind driver's headlight. or (b) when you turn ignition on, ABS lights up on your dash board.
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
