gst fat
- 284
- 1
- Jun 22, 2007
Miami,
Florida
okay so im running an evo3 IM and Evo3 TB,what throttle body gasket should i be using? a 1g? ### right now theres a 2g gasket on it and i beleive its leaking
Note: This feature currently requires accessing the site using the built-in Safari browser.
yes use a 1G as the 2G is much smaller and will hurt airflow.
Auto Zone and O'Reilly's don't exactly stock JDM Evo III gaskets, but hey, if your local car parts store in Iowa does then go with the Evo III gaskets Absit.
Real quick, I believe it is the "outer" gasket that I need correct? I am gonna be using a 1g n/t tb91-94
A 90 TB will not work on a EVOIII intake.
...you can get all the intake gaskets you need for $7 at your local auto parts store and it won't get brittle and blow out under boost after a year or more of heat cycles. Permatex Ultra BlackIf you're stuck on ordering OE composite gaskets then you need the inner gasket, the outer gasket would go between the UICP and TB but since you're installing a 1g N/T TB you'd use the inner gasket between the IM and TB and a silicon coupler between your UICP and TB.
as long as it is compatible with any chemicals that will/could come in contact with it, and it is within the products temperature rating, I don't see why it would not.Thank you gofer! I have The Right Stuff. I'm assuming that'll work just fine then?
91-94
I own 2 90's but I dont use 90 TB's. Only in a terrible pinch would I even want to try to make one work on a EVOIII manifold. But if it's all you have, well anything is possible. I have 2 90 TB's collecting dust. Sensors are just stupid priced for them.
91-94
