Question about wheels
hoonigane
5+ Year Contributor
123
10
Jan 4, 2018
Siauliai, Europe
Hello, anyone knows for sure what is center cap diameter for this rim? And did those rims came originally on 1g's or only on 2g's? I have searched info on google about center cap but it is really confusing, because there are a lot of different rims and not many sites have bore size stated.
Thank you. Need some info on center caps too tho so I could order them.
MR333890 is the part number but i still fail to find a diameter. And i cant find them on ebay with that number
Can confirm, they came on 98 Spyders anyway. Here some pics. I can't find my calipers at the moment, but, the inner bevel of the cap measures 2 1/8", the outer bevel 2 1/4". You'll need the spring clip pictured as well. They go in from the front as well. Part number on mine is MR244232
Thanks for the reply its helpful. I have now found some on ebay 2.25in caps but they seem to be without those metal clips. Are they a must?
Yeah, I think you'll lose the caps otherwise, or they'll fall into the bore and get chewed up. And if you cement them in somehow, you won't be able to get the wheels balanced without taking a chance on breaking your new found caps, they crack easy (at least 20 year old ones do). You could probably find them in a junkyard behind other Mitsu center caps. Oh, and I was wrong in my post above, I believe the caps actually go in from the back, sorry.
