gst_Jake99
- 34
- 4
- May 3, 2016
South Mills,
North_Carolina
When logging in EvoScan, Airflow/Rev load reads up to 200 and stops. When using 2Byte MUT load, it seems to be logging fine upwards of 220. What causes this flatline and is there anything to do to fix it, short of only logging 2byte load?
Also, I have 750cc FIC injectors and a Walbro 255 fuel pump but in order to get A/F and fuel trims right, my Scaling is at 586. What gives? Latency is as follows
4.69V 3.555ms
7.03V 1.290ms
9.38V 1.155ms
11.72V 1.095ms
14.06V 1.095ms
16.41V 0.900ms
18.68V 0.600ms
Thanks, Jake
(EDIT) Scaling is set to InjectorScalingDSM, not InjectorScalingEVO
4.69V 3.555ms
7.03V 1.290ms
9.38V 1.155ms
11.72V 1.095ms
14.06V 1.095ms
16.41V 0.900ms
18.68V 0.600ms
Thanks, Jake
