Question about JB Weld drying time. . .
Posted by 98FWDSM, Jan 15, 2005
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support JNZ Tuning
  1. 98FWDSM
    98FWDSM Proven Member , VirginiaUS
    DSM Profiles:
    Jul 27, 2003
    179
    ok, if anyone has been keeping up with my last post then you will know that i have a crack in my valve cover...well i used JB Weld to fix it (hopefully)....anyways i put it on at 6:15 tonight and was wondering if it would be ready for me to drive at 7:45 tomorrow morning...that is 13.5 hours of drying time but the package says "dries fully in 15 hours"....do you all think that i will be ok to drive it at 7:45 if i am really easy on the car (thus keeping the pressure down) or do you all think that i definetly need to wait the 15 hours??? also, it is about 40 degrees out.
    Thanks :thumb:
    #1
  2. Defiant
    Defiant DSM Wiseman glorious Galt, California
    DSM Profiles:
    Jan 13, 2003
    25,202
    118
    If it has a good grip on the surface, it's okay if it's not fully cured. The oil heat will finish it up. It should be fully-skinned. Don't go poking at it, just leave it alone.
    #2
  3. luv4turbos
    luv4turbos Proven Member Argos, Indiana
    Aug 17, 2003
    71
    I let mine cure for 24 hours. Why take the chance.It's only one day. Or you could have to redo it and take 2. Just my $0.02
    #3
  4. PaleDSM
    PaleDSM Proven Member Dublin, Pennsylvania
    Oct 25, 2004
    588
    I have used JB Weld to fix pinhole leaks in welds and stuff and it has held up to pressure in much less curing time than 15 hours. I think you will be fine.
    #4
  5. IHeartTurbo
    IHeartTurbo Proven Member Weld, Maine
    Aug 15, 2003
    1,351
    15
    Yeah, when I fixed mine, I only waited at the most 2 hours. But that was because I had no choice. It held up fine tho.
    #5
  6. defrag010
    defrag010 Proven Member Fort Smith, Arkansas
    Sep 24, 2004
    391
    You can usually mix in a little bit more hardener, and it will fullly setup a few hours sooner than usual.. It won't set as quick in the cold, though.
    #6
  7. JiveMasterT
    JiveMasterT Proven Member Chest of Westerson, New_York
    Jan 3, 2004
    1,207
    7
    i used jb weld on my old gauge pod when i broke it :cry: and i let it sit until the following morning before i put it in. just let it sit, its not worth breaking it because you got impatient. 24 hours i believe is what it says on the package...
    #7
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
