Chaoticdopey
- 122
- 3
- Sep 29, 2014
Lancaster,
California
ok so to start i had a valve drop and lodge itself into 1 of my Ross pistons, it put a hole in the piston but did not go all the way through, i was wondering if i could just have it tig welded and be fine, but in the likely event i have to get new pistons, i was told the block was .020 over but if i get new piston do i have to go .040 over or can i keep it .020 over as i dont want to cut any more material out of the block.. im just trying to get the car back up and running as i just got a new head, had it hot tanked and had evo 8 valve springs and retainers installed so my valves done float again with the crower 272s.
Do any of you GURUS think this can be fixed?
