Put in new starter car still wont start
Posted by TODD DA HUSTLA, Sep 12, 2002
  1. TODD DA HUSTLA
    TODD DA HUSTLA Proven Member
    163
    Joined Aug 15, 2002
    i jus put in a new starter in today and the car still wont turn over the only way the car will turn over is wen i pop into gear.....anyone have any ides im thinkin maybe the wiring set up is messed up....is there a fuse or somethin that i shood check?maybe the battery wires are not producing enoff juice....please help thanx
    Log in/Register to remove ads
  2. EezO
    EezO Proven Member
    8
    Joined Sep 12, 2002
    Not ment to be a stupid reply but are you absolutely sure you are grounded properly (tight at the battery and tight on the chassis). new battery etc... ive done it before... replaced everything imaginable and then you wiggle the negative and get loose terminal confirmation. does the car die if your idleing at stop but seems normal if your driving (above idle speed) <replace the battery and terminals on the wires>
    before you do anything, go at the terminals and the corresponding wire connections with a brillo pad (or something like it) especially if you have something that looks like a mushroom on the positive battery terminal.
  3. TODD DA HUSTLA
    163
    Joined Aug 15, 2002
    I know all about the corrosion and that mushroom stuff....Actually im not the one who put tha starter in....My buddy who runs a shop put it in 4 me..and he tested it and said it worked...When i had the old starter in it woodnt even attemp to move ...now with the new one...i can hear it popping out...u know the bendix that rotates the engine... its popping but not rotating...Maybe not enough battery juice.....The battery doesnt seem weak...but maybe it is....and all the cables are ok....Im cluless at this point.........
  4. mcerria
    mcerria Proven Member
    83
    Joined Jul 17, 2002
    OK...to start...to get rid of corrosion use a paste of water and baking soda fizzle that sh*t away nicely..............
    Now.....when you turn the key does the starter just engage or does it also try and turn the engin over......You said your friend tested the starter, in the car or out of it?............Does your car have the coil pack or distributor cap? Timing could be horribly off. Same thing was happening on my Dad's van and the timing was just way off after replacing the distributor......
  5. TODD DA HUSTLA
    163
    Joined Aug 15, 2002
    The starter i think is jus engaging ..it making s popping noise...and If i roll it and throw it in gear it still starts...the starter is not rotating the engine at all...Could it possibly b the wrong starter? they tested it off the engine i got the distributorless one..it like its grabbing the flywheel but its not turning it...u know wat i mean??
  6. TODD DA HUSTLA
    163
    Joined Aug 15, 2002
    the problem was ...when the shop ..put the starter in...he ran a double positive...to the selonoid...so i removed it myself........hooked the cable directly to the battery..like ur suppose to....and she firedright up...i knew it was something stupid..i shood go back and tell his ass..and he calls himself a mechanic and couldnt do something so simple
  7. LaserRST
    LaserRST Proven Member
    339
    Joined Oct 6, 2002
    ...heh...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
