Please Support Morrison Fabrications
1G protruding wheels back
Adrian97
5+ Year Contributor
100
Mar 3, 2018
Göteborg, Europe
Hello
I want to know if only my GSX 1G has it
I have same tire size at the front and same wheels , same offset , there is NO wheels distance but
The wheels at the back are more distant/protruding than the wheels at the front its looks llike this
Its normal?
Did you measure the width? I've had multiple sets of wheels and if everything is equal I've never has a set protrude out the back and not the front. Either way I doubt it's an issue.
Thank you for your response.
no, I will have to measure :)
and I will try with other rims
Thats strange. It should be the complete opposite if anything. Almost all cars, if not all, have a narrower track width in the rears so they will always be sunk in a bit depending on how wide the body is.
Swap the wheels around and double check offset is the same.
