- Thread starter
- #76
jamel16
- 282
- 234
- Aug 6, 2004
Richmond,
Virginia
UPDATE # 2:
The final install of this update will be installation of the turbo components and fabrication of the oil feed, oil drain and vacuum/ boost pressure lines. I can’t wait to see how this turbo performs in the .55 BEP housing. The turbo consists of a 76-mm turbine housing, the O2 housing is an XS power unit that I upgraded with Tial components. The waste gate spring is a 20-psi unit that is connect to a turbosmart dual mbc.
Next installment will consist of all the wiring such as both wiring harnesses, fuse and relay boxes, etc. See you then.
