Please Support Kiggly Racing
Please Support STM Tuned
1G Power steering/ oil light.
GSX93DSM
610
4
Jan 3, 2006
Staunton, Virginia
I need some help.My car wants to die when i turn the wheel left or right.I hooked up the pressure switch with is the yellow wire correct? When i turn the wheel the oil lamp comes on then goes off when the wheel goes back to center.The oil sensor it's not hooked up.Any help would be great.
I believe you have the wrong wire. When I had to fix that side of my harness, I hooked up the oil light wire to the p.s. pressure switch. I quickly figured it out and swapped them and no more oil light. You can do a continuity test from the wire in the engine bay back to the proper ecu pin for the pressure switch wire. That was the way I figured out which wire was which.
