AWD-Tony
- 6,801
- 3,735
- Sep 11, 2017
Cincinnati,
Ohio
Hey guys! I had the p/s door panel off to fix a stuck lock cylinder...Love it when you don't need to spend money to fix something. FYI you do not need to remove the handle assembly to remove the lock cylinder. Anyway, I noticed it had a door lock actuator. It also has the module on the p/s kick panel and the board looks mint. 15 amp fuse on drivers side fuse box is also fine. There's no switch on the drivers side for lock/unlock. I was wondering if the 1g's came with a switch by the window controls for power door locks. If they didn't, does power door lock work when locking/unlocking with key. And is there anything else I can check?
Thanks, Tony!
Thanks, Tony!
