AntmanAndLittleDi
- 161
- 15
- Nov 12, 2014
Russell,
Kansas
We just went through nearly a whole electrical rebuild on our 1999 Eclipse GST. Replaced turbo, motor mounts, spark plugs & wires, ecu, broadband O2 sensor, fuel pump, throttle position sensor, coolant temp sensor, fuel injectors, flex pipe on exhaust, harmonic balancer, radiator hose, .... thinking there's more, but can't remember. Anyway, long story short, we still can't get the car to stop running rich even after fixing all of these problems. Our neighbor has a scanner that he gladly brings over and runs codes for us which is finally showing no more electrical/sensor problems. While driving it around, we noticed suddenly the O2 sensor was reading about 12.5 when typically it would run 9.5 - 10.5. Rather than assuming it fixed itself, we took it back home, opened the hood and found a cap on the air intake had blown off... seriously blown off, ripped the threads out of the cap. For a temporary fix we put the cap back on and wrapped it with gorilla tape. We couldn't leave the cap off because it is located after the air filters and after the mass air flow sensor, which any dirt would go straight to the motor. After putting the cap back on, the O2 sensor went back to 10.1 at an idle. The air filters are fairly new, put in a couple months before we bought it in July this year and still look very clean. Is there something we are overlooking? As is the car only gets 9 - 10 mpg and it doesn't matter if it's in town or highway miles. Eager to get this baby running like a champ so we can give her a much needed paint job. Any help is much appreciated!
