wastefuldreamer
- 1,646
- 5
- May 11, 2002
Bloomingburg,
New_York
carbine bits my friend
Note: This feature currently requires accessing the site using the built-in Safari browser.
do NOT try this at home unless you have a heavy-duty air or electric die grinder and carbide bits. It will take HOURS as is. If you try this with a Dremel, you'll be lucky to finish it in days or weeks.
WHITE GST said:So wich one is better guys, air or electric grinder? if electric is better Sears has some on special, for like 29 bucks they are Craftman with like 65 different bits, 35,0000 RPM. I'M thinking in buying one but i don't know if i should get an electric or air one, my brother has a compressor so a can get wich ever is better for about the same money. I need to port my o2 housing and the turbine housing because i'm having some bad boost creep.
TurBoGs-T said:Both are good, but as stated in the vfaq you need to have a heavy duty air compressor. You are going to be all day with a small air compressor that you get a couple min of use and have to wait to fill it up. If you have one where you can keep going for a long time then go for it. I personally would go with an electric one because you can keep going and going and going nonstop.
a_scobel said:It says don't use a Dremel, though.......?
mgcook said:you could always try to use a drill
but i'd suggest getting a dremel, they arent very expensive
