Nuzzi
- 158
- 5
- Jan 11, 2014
Torrington,
Connecticut
91 Talon tsi, im installing a full set of poly mounts and have a couple issues. The rear mount that was in the car had an off center bolt hole, but the poly replacement was centered? I was able to get it bolted up but just wondering if that sounds right. As for the front the poly mount is one piece with a lip on both sides, the others were all split. Is this supposed to be split as well or do you normally get it pressed in? This is what im looking at
Got it all installed, doesnt shake nearly as bad as people made it sound. Slightly more than stock. The only thing that made it difficult and im slightly wondering about is the stock front and rear mounts had offset bolt holes but the poly were centered. Made it a pita.
[DOUBLEPOST=1408805123][/DOUBLEPOST]Nm, getting it pressed in as i type.Got it all installed, doesnt shake nearly as bad as people made it sound. Slightly more than stock. The only thing that made it difficult and im slightly wondering about is the stock front and rear mounts had offset bolt holes but the poly were centered. Made it a pita.
