Ludachris
Founder & Zookeeper
- 8,053
- 3,071
- Nov 12, 2001
Newcastle,
California
So when you slide the cable over the pin there's a plastic bushing that gets stuffed in to prevent play. Then the cotter pin keeps it all together, or if you're using a short shifter, an e-clip is used. Either way you still need that small plastic/nylon bushing. Is that a dealer-only thing? Anyone have a part number? I keep finding the larger version that goes over the shifter lever pivot point, and tons of discussions about the metal bushing replacement options.
