- Thread starter
- #26
pksystems
- 677
- 136
- Nov 9, 2003
Calgary,
AB_Canada
Since Tan/Beige carpet stains so easily I decided to change the colour to black.
Pulled the underlay off of the trunk and passenger compartment carpet. (That stuff will suck up tonnes of dye, and doesn't need to be black)
Vacuumed both.
Pressure washed them both on sidewalk.
Treated any major stains with carpet cleaner/wet carpet vac. then cleaned entire carpet with wet carpet vac.
Soaked/agitated them in various different cleaners in the bath tub. Awesome Orange, Laundry soap + Resolve Oxi...etc.. I gave them 2 soap soaks, 2 rinses, 2 soap soaks, kept rinsing till no more bubbles.
The water was like black the first time, and got lighter and lighter. The water was still not clear on my final cleaning, but I think the hot water was starting to leech the colour out of the carpet. There is no way there should be any more oils in the carpet.
Picked up a 150L plastic storage container, 6 bottles of Rit Dye, 1 box of salt.
Turned up the water heater a bit. Hooked garden hose to my hot water laundry tap, and ran it out the window. I don't want to risk this giant tub of dye leaking into finished basement.
Filled up the tub, dumped in the dye, dumped in the salt, mixed it all up.
Toss in the carpet, move it around a bit with gloves/stick. Once I was satisfied that it was thoroughly soaked I placed some rocks in ziploc bags on top of the carpet to keep it under the surface of the dye. I will leave it in the bath for 5 days. We will see what it looks like. I will pull it out, lay it in the sun, and if it's not dark enough or there is any marks from the folds, I will mix up more Rit in a spray bottle and coat it again.
The sanding on the CF overlay trunk cover continues.
The epoxy tends to run into the low spots on the cover, so I've been forced to coat it sitting on edge a couple times. Of course I'm getting crazy runs all over the place, trying to get a decent coat of epoxy over the carbon weave. I think I'm nearing the end of epoxy coats/sanding tho. I have a nice dull (non-glossy) surface except for a couple small areas, that will need another coat. Then I can start polishing this thing. The roof, and door panels should be easier then the cover.
Front end of the car is on stands, and all the suspension/brakes have been pulled. I have to figure out which arms will be replaced, and which will be refurbished. I have the ES front bushing kit, but it doesn't have anything for the curved arms, and only replaces one bushing on the straight lower arms.
I will probably outsource some of the sandblasting to a local company, since I want this thing on the road before it starts to snow. My compressor is on the low end of what is usable for blasting parts and it is taking way too long.
Started pulling out the ABS crap. ABS pump weighs like 10lbs. Now that it is out, I have room for an air oil cooler. I can start removing this mess of ABS brake lines. All the brake lines under the hood did not require vice grips to disconnect, so I will rebend/flare the lines for non-abs use. Brake master cylinder will be replaced with a new 3G cylinder, with the reservoir mounted right on the mc.
SR Performance Outlander front rotor beside stock GSX. I am using the 05/06 Outlander caliper bracket which allows bigger rotors.
Vacuumed both.
