1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Piston Skirt Coating
Posted by bastarddsm, Apr 19, 2018
Please Support STM Tuned
  1. bastarddsm
    bastarddsm Supporting Vendor
    4,264
    865
    Joined Aug 26, 2003
    Mendota, Illinois
    Hello Everyone,
    I assume everyone these days know the benefits of coating technologies, but just in case I'll give a brief description. Piston skirt coatings are typically a Molybdenum Di-sulfide based dry film lubricant. Moly is an extremely high pressure lubricant that survives when many other lubricants fail. Coating pistons skirts helps reduce friction, and reduce the chances of galling due to extreme loads. This is essential because even a modest 4G approaches 100hp/cyl, a point that would be considered "extreme race" in most of the rest of the world.
    So a few years ago I built a motor with these really nice JE pistons that had coated skirts. I ended up hurting a piston and needing to get it re-coated. After many phone calls and much time I decided it was just best to do it myself. So I did the research, procured the materials, and coated a set of pistons. After 3 seasons of successful testing, I can finally offer this service. Prices start at $100 for a set of 4.
    Here's a picture of the finished coating,
    Here is the set of pistons after 3 seasons of abuse - Keep in mind this is 600+whp and gets taken to 9500 every pass, and I go racing a lot. This thing has had many 50psi excursions, and has never trapped less than 130, and has been 140's for the last 2 seasons.
    Log in/Register to remove ads
    My DSM:
    1991 Eagle Talon N/T
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
    wasabi37, Kapok6, SAKJR and 2 others like this.
    Featured Products from our Supporting Vendors
  2. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    3,211
    1,045
    Joined Nov 14, 2013
    Independence, Kansas
    Thanks Kurt, for a new service for the community. Seems reasonably priced to me!
    Your car speaks for your work, and it is a mean machine!
    Marty
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
    14b   automatic
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 MPH
    13.612 @ 107.760 MPH
    Loading...
  3. Tanro
    Tanro Proven Member
    1,470
    71
    Joined Jul 22, 2009
    Montgomery, Alabama
    Hot sh** dude. That is out f***ing standing work. And you can get this done for us at 25$ A piston? That is just excellent. If/when I get around to building a shortblock I will be sending you a set.
    Those pistons look absolutely amazing considering the stress load you've put them through.
    My DSM:
    1999 Mitsubishi Eclipse GST
    Street Build
    16g   manual
    Loading...
  4. bastarddsm
    4,264
    865
    Joined Aug 26, 2003
    Mendota, Illinois
    Yes well $100 for a set of 4. Singles the price'll go up a bit - setup is most of the work so it's easier to do groups. And to be fair most others do it for the same price, but usually turn around time and not loosing your parts is an issue.
    Also I don't have a thermal barrier type coating, I could probably figure it out, but I just don't believe in them.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
  5. ViciousLord
    ViciousLord Proven Member
    355
    48
    Joined Jul 27, 2005
    Orlando, Florida
    Could this coating be used for other areas in the block and or head? Just thinking outside the box.
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
      manual
    Loading...
  6. bastarddsm
    4,264
    865
    Joined Aug 26, 2003
    Mendota, Illinois
    Yes, you could do like bearings, inside of the piston pin bore, ect. I've not done anything outside of piston skirts, so it would be an experiment.
    I think that maybe 2g thrust bearings would be a place to try it. Rod/main bearings don't need much since they have a constant supply of fresh oil and ride on a hydrodynamic wedge. They ride on a wave of oil and there is never metal to metal. Piston skirts and thrust bearings don't work the same way and there is much more likelihood for metal to metal.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
    Teezy, Kapok6, AllanL and 1 other person like this.
  7. m_0ney_pit
    m_0ney_pit Proven Member
    577
    27
    Joined Jan 12, 2007
    Reading, Pennsylvania
    Will you coat stock style NPR type piston skirts?
    My DSM:
    1998 Eagle Talon TSi AWD
    Street Build
    14b   automatic
    1999
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
    Teezy likes this.
  8. bastarddsm
    4,264
    865
    Joined Aug 26, 2003
    Mendota, Illinois
    Yes, but they need to be off the rods.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
  9. m_0ney_pit
    577
    27
    Joined Jan 12, 2007
    Do you grit blast the skirt before coating?
    My DSM:
    Street Build
    14b   automatic
    1999
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  10. bastarddsm
    4,264
    865
    Joined Aug 26, 2003
    Mendota, Illinois
    Yes, that's why they need to be off the rods. The pin bores and ring lands are masked off.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
  11. m_0ney_pit
    577
    27
    Joined Jan 12, 2007
    so the coaters typically brag about not having to change clearances after blasting and coating. Personally I have seen mill finished aluminum (forged probably swells less) swell up to 1 mil after blasting with oxide so both sides plus maybe a half mil of coating you beef up the piston diameter about 2.5 mil after the process. What's your take on doing the machine work and then coating or coating and then machine work?
    My DSM:
    Street Build
    14b   automatic
    1999
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
  12. Jon Lane
    Jon Lane Proven Member
    340
    14
    Joined May 1, 2004
    SW, Florida
    This is fantastic work, OP. I know that while I'll never race, your posts are still always worth studying. You know what you're doing and the content of your comments is educational.
    However I've got an experience with split 2G thrust bearings in a NOS 7-bolt build to relate. This particular new crank and block didn't like aftermarket thrust bearings. A set of Kings and two sets of coated ACLs were all too thick - giving just slightly under .002" end play - and only the OEMs were thin and consistent enough to fit.
    Measuring the aftermarket sets showed that they were all less flat than the OEMs too. This lead to mixing and matching one good pair out of the eight pieces. It also led to ever so slightly emerying the final pair in order to flatten them.
    In none of these cases was the coating the apparent problem - the aftermarket shells themselves were thicker and less flat. In the case where the end play is already on the low end of the scale, and in a touchy application where flatness is key to a successful oil film, it could be - based on this limited experience - that a 2g split thrust coating service could benefit from truing the shells first.
    Is that possible or is this just an unusual experience?
  13. bastarddsm
    4,264
    865
    Joined Aug 26, 2003
    Mendota, Illinois
    That's interesting and something I've not considered. I've always coated first, and then machine. It typically measures about a .0005" coating thickness, so finished size is .001" bigger. I take about .0005" off the clearance for for the coating. IE, my target clearance is .0045, so I set the actual clearance to .004". I just did a new set of JE's out of the box they measured 3.3625", after coating they measured 3.3635". The whole thing gets tricky since aluminum grows .0005" per 10*f and you and you need to preheat the pistons before you spray them, so you are working with a range of temperatures.
    I never measured one after blasting, I'll check that out next time. The blasting is fairly soft -150grit aluminum oxide at like 50psi.
    Thanks Man!
    I totally agree. The coating process is additive and defiantly would add to the thickness. I've not had any issues with thrust bearings, but I do know it's common to hold a pair together with a hose clamp and flat sand them on a piece of 4-600 wet/dry on a piece of glass. The nice thing is the coating would wear from the high spots, and you should end up with a nice flat surface. I think this would require quite a bit of experimentation to get it right though. Thinking about this gave me a great idea for a tool to square up the thrust bearings in the block.
    My DSM:
    Showcar Build
    9.805 @ 144.00 MPH
    Loading...
    SAKJR likes this.
  14. m_0ney_pit
    577
    27
    Joined Jan 12, 2007
    Valve stems, I coated a set of 6t valves used tin foils to mask the seat and seal top/bottom when I put new rings in the 6 bolt last summer.
    My DSM:
    Street Build
    14b   automatic
    1999
    Street Build
    16g   manual
    Street Build
    14b   manual
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
