toicy4ya
- 108
- 1
- Jun 9, 2005
Bronx,
New_York
I have a Pioneer Head Unit (model#DEH-P8600MP), upon reading the installation manual I read some conflicting information. The Manual reads, "When an external amp is being used be sure not to connect the blue/white lead to the amp's power terminal. Likewise, do not connect the blue/white lead to the power terminal of the auto-antenna. Such connection could cause excessive current drain and malfunction." However, the diagram to the left of it clearly show's the Blue/White lead connected to it and reads "to system control terminal of the power amp or auto antenna relay control terminal." Which is it? I'm confused?
Additionally, I'm a little confused on the yellow and red wire from the radio. My car has a "ACC Position" which wire should I connect, the Red (which reads to electric terminal controlled by ignition switch (12V DC) On/Off) or the yellow (To terminal always supplied with power regardless of ignition switch position)? Or do I connect them both? I noticed my brand new battery has been draining a little bit and I have a sneaky suspicion this might be the cause. Please get back to me.
Thanks
Thanks
