SpawnedX
Banned Member
- 4,017
- 51
- May 18, 2004
West Warwick,
Rhode_Island
Let me see what I can find out for you, because I have never worked with an auto 6 bolt. Give me a few minutes. I have CAPS so I am sure I can find the part number.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I have no idea. Thus I will not relinquish mine I gave my last one to a guy wanting the stock flexplate and the auto transfercase. I'm not letting any more go since my 5speed is on it's last leg anyhow .
But you know your problem anyhow. I'm sure SOMEONE can help get you one. Sorry it took so long to figure it out
my local dsm shop might have some laying around, I will look, if it costs less than $10 to ship I will help you out.
I'm just going to agree here that you need that spacer plate. If nobody local comes through quickly let me know and I can ship one out to you. I'm pretty sure I have a couple laying around.
After that it's going to be trial and error again, you definately have the plate fitted the correct way now though.
Is this a USDM trans? Or a "JDM" one??? Judging by the convertor size it looks to be a JDM Trans and that is completely different then the USDM trans. The bellhousing, Convertor, plate, starter, Intermediate shaft are all completely different then the USDM versions and the kiggly plate will NOT work with it...
But that's my guess as to your issue...
HUH . No bro my stuff isnt JDM its factory. We are thinking the issue is the pilot bushing is backwards
Hey guys im doing the exact same thing right now here
Do you have to use the adapter plate in conjunction with the old plate ???
i want to get this together soon
just leave your opinion
WHAT? I didnt understand your question
You have to use the Kiggly 6 bolt tranny kit. Theres no other way around it.
Yes thats exactly what im doing my question was if i still have to use the plate the one that goes between bell housing and engine he one that has a hole for the starter
also you know the adapter plate how thick it is i was thinking that we prob have to modify the starter because now its gonna sit farther from the torque converter that before
Did you finish yours ???
The orange in this picture indicates where the spacer we are referring to goes. It looks like it is not a kit piece, so it may utilize a stock spacer, probably not used on a 7 bolt, which is why it seems you don't have it.
I'm working with this same kit right now actually. So from what I'm gathering here is that the bolts that hold the flexplate to the crank are too long? And that's why this spacer is needed?
