Calan
DSM Wiseman
- 7,251
- 363
- Jan 16, 2007
OKC,
Oklahoma
I was thinking the same thing. If he'd just give up some of that Michigan militia stuff, we'd probably already have a new PS pump design to work with.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I've already removed the factory handle assembly and cables. I still need to gut both rear hubs. I just planned to do without a parking brake from now on. It's going to take me a minute to get used to not having one, but I'll live.Always loved your car Paul. I can't wait to see more updates.
What are you going to do for a parking brake now that you've got the staging brake?
If someone wants to donate a garage, an MVR and a V60, I'll gladly get started right away!
I'd love to, but Tial is only going to produce the housing for the GT40, and not the GT40r. No ball bearing love. I was really bummed out when I found out.Im also guessing your going with a tial ss vband housing on the gt40 would be smart to.
Another thing to add to the "to do" list: Tubular rear subframe. And I'll be starting it very soon.
Not alot of hills at all around here. I don't street drive it often though, so I'm not too worried. I've also never had a tranny pop out of gear either, so I wouldn't worry too much about that either.
It bleeds pressure with time, so it won't work for extended periods. I had considered building some sort of bracket to lock it upward until I found this out.
Yup, I love those things. O-rings, flat surfaces, and properly torqued L19's, and you won't have any issues sealing one either.Still running a composite head gasket? If so, what's your secret to keeping em together?
I wouldn't know. I went to an o-ring after 400 whp. I run a Mitsu gasket on this car, but I use the Felpro gasket on everything else.What about without o-ringing? Will they still hold in excess of 600whp? Are you using a Mitsu gasket or a felpro?
No real reason. They're practically identical.Any reason why you picked the mitsu over the felpro? Sorry for the dumb questions, just trying to get a good grasp
