Partial emissions delete?
Posted by anokh3, May 23, 2011
Please Support Jackson Auto Machine
  1. anokh3
    anokh3 Probationary Member
    20
    Joined Jun 9, 2010
    N. Kingsville, Ohio
    I want to clean up the engine bay. I've seen tons of threads w/the diagrams and what not, but I was wondering if I could tackle this over the course of some time (I work slowly, since I learn as I go). Can I remove some of the hoses and cap them off without completing the whole thing in one sitting or would there be a problem driving around like that? I couldn't find anything through the search about what you can remove / what would be the consequences if you only remove some of it at a time. I don't mean to turn it into a huge debate, just wondering if anyone thinks it would be alright to remove some vacuum hoses / cap them off without doing it all at once. Hope its not too stupid of a question, and thanks in advance!
    Log in/Register to remove ads
    Loading...
  2. TsiJohn333
    TsiJohn333 Proven Member
    266
    7
    Joined Jan 25, 2010
    Goffstown, New Hampshire
    The only stupid question is the question not asked. for your emissions delete, what are you planning on deleting. I take it that your gonna remove and cap off the vaccumm lines on your tb, remove all your emission sensors with the vaccumm lines. are you going to be removing the EGR valve and using a plate to block it off. if your gonna do just the emissions delete, i suggest to just do it all at once. it shouldnt take long to delete everything.
    My DSM:
    1991 Mitsubishi Galant VR-4
    13.472 @ 101.970 MPH
    Loading...
  3. Orange Car
    Orange Car Proven Member
    32
    Joined Apr 24, 2011
    Redford, Michigan
    Do it all at once... If you have concerns, perform a boost leak test after each delete.
    EGR removal will buy you the most new found space.
  4. RedDragonGSX97
    RedDragonGSX97 Proven Member
    34
    Joined Nov 13, 2011
    Johnson City, Tennessee
    Not trying to revive a dead thread but i have a similar question. I just bought another 2g turbo throttle body as mine has major boost leaks. I want to do delete emissions but I wont have time to really work on it till next week. i would like to have the ports welded closed while its currently off the car. if I weld them and put the tb on can I leave the vac lines just hanging there unplugged without any issues until next week when I can yank all the emissions crap. Any help is appreciated
    Loading...
  5. 1g-awd-talon
    1g-awd-talon Probationary Member
    19
    Joined Jun 27, 2012
    Martinsburg, West Virginia
    I'm new this but AS I read and re-read the diagrams I don't believe you can just leave the hoses hanging because that would cause a vac. leak but a thought would be to put a screw in the lines so you are blocking off the vac leak. Correct me if I'm wrong. everyone
  6. RedDragonGSX97
    34
    Joined Nov 13, 2011
    If I unplug the lines from tb then they wouldn't be getting any vacuum woul they.I had intended to plug them with a screw
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
