1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
2G Parasitic drain from heater relay circuit?
Posted by eclipsed123, Sep 15, 2018
Please Support STM Tuned
  1. eclipsed123
    eclipsed123 Proven Member
    105
    Joined Feb 28, 2009
    Newnan, Georgia
    So as the title states I'm getting a battery drain from the heater relay circuit and I'm not really where to start to fix the problem. When I shut the car off the green light remains on the a/c controls (has a snowflake image below it) I have to pull the fuse so that my battery doesn't die every other day any advice of where I should start to fix the problem?
    Log in/Register to remove ads
    Featured Products from our Supporting Vendors
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
