Rustic gst
- 66
- 2
- Sep 14, 2016
las vegas,
New_Mexico
hey guys so i recently had a idle surge between like 300rpm and 900 and i could idle right. it never died on me once started but i do have a cold start problem. i replaced my idle air control valve and it didn't seem to change. so i took my throttle body out, cleaned it and closed off the fiav. now my cars idle is really high between 1200rpms to 1800 rpms. is there any way to test the connector to the iac valve to make sure that my wiring to the sensor is not bad? also i can plug and unplug the connector on the iac and i see no noticeable change in idle
