p0100 help, already searched
Posted by jpphilli37, Mar 7, 2006
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Magnus Motorsports
  1. jpphilli37
    jpphilli37 Probationary Member
    Dec 1, 2005
    24
    Lafayette, Indiana
    my car gives a CEL p0100 and p0420.
    it is running EXTREMELY rich and sometimes stalls when idling.
    i have checked the MAF and it is good.
    i also tested the injectors and did a compression test on the engine and they check out.
    O2 sensor is good also.
    what else could i check?
    i am getting about 5mpg!:confused:
    my car is a 99 gsx with injen intake:dsm:
    #1
  2. EclipseTrbo420A
    EclipseTrbo420A Proven Member
    Jan 23, 2004
    1,868
    37
    WhiteOak/PGH, Pennsylvania
    did you get the code pulled ? 5 mpg sucks, it might be cheaper to order a Logger than to drive to the local autoparts store and get it pulled :p GoodLuck.
    #2
  3. jpphilli37
    Dec 1, 2005
    24
    Lafayette, Indiana
    i had the code pulled at autozone
    #3
  4. EclipseTrbo420A
    Jan 23, 2004
    1,868
    37
    What did it tell you ?
    #4
  5. jpphilli37
    Dec 1, 2005
    24
    Lafayette, Indiana
    P0100 Mass or Volume Air Flow Circuit Malfunction
    and
    P0420cataylist efficiency sensor below threshold for bank 1
    #5
  6. 4G63Boosted
    4G63Boosted Proven Member
    Jan 10, 2006
    115
    5
    Lynchburg, Virginia
    Is your MAF harness plugged in all the way? I know this sounds stupid, but I have done it before myself. Made me feel pretty dumb once I figured out what it was.
    #6
  7. jpphilli37
    Dec 1, 2005
    24
    Lafayette, Indiana
    yes it was plugged in. i even switched it out with my friends. the thing is that there is no difference while the car is running whether the MAF is plugged in or not. could the problem be in the wiring?
    #7
  8. tsimike97
    tsimike97 Probationary Member
    Oct 29, 2005
    10
    port royal, South_Carolina
    how long has it been doing this?? Did you use VFAQ to wire your AFC?? Just found out that VFAQ is wrong, and P0100 code clears for good when your AFC is wired correctly. A buddy of mine had the same problem. Let me know i can send you the correct wiring diagram.
    #8
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
