Russ98GSX
- 0
- May 3, 2013
Monroe,
New_York
I have a 98 GSX.
I've replaced the head gasket, valve seals, had the head machined, put in head studs, new hoses, aluminum radiator, thermostat, radiator cap, the fans run all the time. The system was acid flushed and bled.
The car is still sporadically overheating. Without boost, with boost, it doesn't matter. I'm at a loss. What am I missing?!
Also, what is the PSI specs for the radiator cap for the 2g GSX Turbo? 13 or 16?
Thanks...
Thanks...
