ShameSaw
- 0
- Apr 10, 2015
Hitchcock,
Texas
Ok, I have a 96 Eagle Talon, n/t.
It just started overheating after I pulled the valve covers to clean them up.
I checked my radiator, and that's fine, I flushed it, pressurized it, flushed it again. My water pump is working, pulling suction as it should, I replaced the thermostat, and tested both fans, relays, and fuses. The fans turn on, the thermostat opens as it should.
I changed the oil and replaced the old transmission fluid with new fluid.
I cleaned my EGR line and tested the EGR, it works fine.
My antifreeze is clean, not leaking, hoses are fine.
My oil isn't milky, looks clean, that's fine.
I don't have a leaking head gasket and I don't know where to look anymore. I'm stuck. Any help would be greatly appreciated.
