marcus28504
- 33
- 0
- Dec 4, 2014
Woodinville,
Washington
I have a 1996 Eagle Talon Tsi
When ever I get on boost it goes straight to 28psi and Doesn't Drop Until i let off the gas
I hooked up my Internal Wastegate on my EvoIII Big 16g Directly to the J pipe nipple and it still overboosts.
The flapper opens 100% by hand No boost Leaks And 20-22 Vacuum
I pulled the WGA off and the rod itself takes nearly all my strength to open and when it does open it opens at an angle like its bent and it scrapes on the metal surrounding the Base.
Could replacing this fix my problem?
Any Ideas on what could be causing this other than the WGA?
