WarrenSen
- 0
- May 30, 2018
York,
Europe
Hi Guys, bit confused, I put the new bearings on the output shaft and commenced reassembly. But solder on the edges, 1.6mm didn't crush or I couldn't tell, so I made two little coils and used them, they crush to 1.45mm/1.5mm this is about as accurate as I can get,
Standard value for pre-load is 0.055 - 0.115mm so this would suggest I need a spacer for behind the outer race of say 1.44mm, theory being .06 would be the mid point so 1.45-0.06 = 1.39 or 1.5-0.06=1.44.
Looking at the rebuild pages MD718521 is equal to 1.4mm so seems like the right one, can any confirm I'm doing this right.
I think I've got it wrong - Preload of 0.06 to 0.115 would be negative wouldn't it? So if I have a 1.45 gap then I need 1.45 + 0.875 to give me midway preload which would be 1.5375 and the nearest to that is 1.55 part number MD718526
Oooh bugger
So that's put tin hat on it, I decided to repeat the exercise and try get a more consistent measurement and one of the output shaft retainer bolts has sheared, no stud at all to get an extractor on and its at the bottom of a 4" shaft approx 10" deep. I'm so pissed off right at the moment, spend a small fortune and no closer to rebuilding this motherf.. I've really no idea where to go with this now, I don't even know of an engineering company in the UK that could tackle this
Cheers
Oooh bugger
Cheers
