Oil On Top Of Engine????
Posted by Zincone91, Jul 20, 2010
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support VR Speed Factory
  1. Zincone91
    Zincone91 Proven Member
    DSM Profiles:
    Mar 19, 2009
    55
    Warwick, Rhode_Island
    This might be a dumb question but idk why its doing this but every time i go driven the talon when i pull over there is always some oil on the top the of motor just sitting there and idk what to do to fix it need some help ### ### :confused:
    #1
  2. DeadsEvolution1
    DeadsEvolution1 Proven Member
    DSM Profiles:
    Jan 10, 2008
    347
    Albuquerque, New_Mexico
    Is there a crack in your valve cover??? That's how mine got oil on the top all the time. Especially under load it would just keep coming up. Happens usually when you over torque the bolts to the valve cover.
    #2
  3. Jonman409
    Jonman409 Proven Member
    Oct 21, 2009
    46
    Millersville, Maryland
    Where is the oil on the valve cover? I ended up having to replace the Oil cap on mine for similar reasons.
    #3
  4. Borgratt
    Borgratt Proven Member
    DSM Profiles:
    Jan 23, 2010
    38
    Auburn, Washington
    Leaky oil cap or maybe oil blowing out your dip stick as well. Those and like said before, cracked valve cover. Is it getting on your hood as well?
    #4
  5. ambush91
    ambush91 Supporting VIP
    DSM Profiles:
    Nov 28, 2009
    109
    Newport, New_Hampshire
    bought a 1g a lil while back and noticed the same problem, the stock bov was vented to atmosphere but there was a bit of oil getting into the intake system so when it would blow off it would spray oil all over the valve cover.
    #5
  6. Billiam
    Billiam Proven Member
    DSM Profiles:
    Sep 7, 2009
    103
    3
    Tinley Park, Illinois
    I also had this problem and it was a mixture of the valve cover gasket and the oil cap.
    #6
  7. Zincone91
    DSM Profiles:
    Mar 19, 2009
    55
    There is oil in the corner of the cover and yes its on the hood
    #7
  8. Borgratt
    DSM Profiles:
    Jan 23, 2010
    38
    Auburn, Washington
    Sounds like you are blowing your dip stick out. I used some zip ties to hold my dip stick down. Some people pinch the tube so it wont come out too easy but i wouldnt do that. You can go buy a new stick from mitsu or maybe from one of the venders here. Clean up what you can and see if you get more oil in the valve cover after fixing your dip stick.
    #8
  9. 98GSXtacy
    98GSXtacy Proven Member
    Jul 13, 2010
    219
    4
    Grand Junction, Colorado
    If it is your dipstick, I believe it is STM, sells a new dipstick tube with a piece on it that holds the dipstick down. Also, If the dipstick is to blame, check your motor for excessive blowby. It should only blow that dipstick out if there is too much backpressure in the crankcase for the seal on the dipstick to handle. Check pcv valve and system and all that stuff just to be safe and everything.
    #9
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
