Oil Leaking into my Spark Plug Well
Posted by xXEclipse, Feb 15, 2011
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support VR Speed Factory
  1. xXEclipse
    xXEclipse Proven Member
    Aug 30, 2010
    336
    Montrose, California
    here is my previous post in which I thought i solved the problem.
    http://www.dsmtuners.com/forums/newbie-forum/393040-bad-oil-leak-what.html
    Turns out this morning I checked and more oil is in the spark plug well. Is there anyway to tel if my VC is cracked besides visibly looking, because I dont see anything, what else could be causing all this oil :confused:
    #1
  2. mazda-man
    mazda-man Proven Member
    Jul 14, 2010
    100
    Street, Maryland
    I didn't see in the other posts but might have missed it but did you replace your spark plug tube seals? If not that is the first thing you do. If so then you can send the valve cover to a machine shop to have them check it for cracks.
    #2
  3. jmkhet
    jmkhet Proven Member
    Feb 11, 2008
    31
    Lowell, Michigan
    Maybe bad spark plug gaskets...I think i read some where VC gasket if tightened in the wrong sequence could do this aswell, but dont hold me to it.
    #3
  4. Alan11
    Alan11 Proven Member
    DSM Profiles:
    Apr 30, 2010
    614
    El Paso, Texas
    even the spark plugs can be the problem...!!
    #4
  5. jmkhet
    Feb 11, 2008
    31
    Lowell, Michigan
    Id just buy a valve cover gasket set off ebay and itll come with the 4 plug gaskets and valve cover gasket.Replace those, and like Mazda-man said...look the VC over for hairline cracks.
    #5
    19Eclipse90 likes this.
  6. 19Eclipse90
    19Eclipse90 DSM Wiseman
    Sep 29, 2003
    4,028
    352
    OKC, Oklahoma
    Do you mean where the spark plugs thread into the head or just under the spark plug cover? If the former, look into replacing your valve cover gaskets as mazda-man suggested. If the latter, the only way to tell is by looking at it carefully and that involves removing it to check the underside as well.
    #6
  7. jmkhet
    Feb 11, 2008
    31
    Lowell, Michigan
    I just found this reply on all experts.com.The guy had the same problem as you, assuming your talking about oil in the plug well.The reply was as follows......
    Oil in the spark plug chamber can mean worn out and stiff valve cover gasket seals. If you replaced the valve cover gasket seals and torqued all the bolts to spec, but it still leaks, your problem may be a warped or even cracked head gasket. Oil can also leak into your spark plug area if your valve seals and/or valve guides are worn out. Replacing any of these items would require rebuilding the entire head.
    Check for other signs of oil leaks around your engine compartment. If you see oil leaks around your alternator (front, driver side), your leak may be from the oil pump or crank seal. Try replacing the PCV valve. That valve relieves pressure under the valve cover. If that valve gets clogged, pressure will be unable to vent out appropriately, and that can force oil into your spark plug chambers, and out of any weak seals. It's the cheapest and quickest solution that you should first try.
    Good luck!
    #7
  8. 19Eclipse90
    Sep 29, 2003
    4,028
    352
    OKC, Oklahoma
    Not all of this is applicable to DSMs or the 4G63 engine. Take that advice with a grain of salt.
    #8
  9. xXEclipse
    Aug 30, 2010
    336
    i just checked the spark plug well bolts under the plastic cover, and they were very loose, does anyone know the amount that im supposed to torque down the bolts?
    Sent from my DROID2 using Tapatalk
    #9
  10. 19Eclipse90
    Sep 29, 2003
    4,028
    352
    OKC, Oklahoma
    Hardly hand tight, 3 ft.-lbs. (that is 36 IN.-lbs.). Be aware that over-tightening will increase chances that you crack the valve cover.
    #10
  11. xXEclipse
    Aug 30, 2010
    336
    Nevermind again! Under one of the bolts there is a huge crack -_- The previous owner obvious ally didnt torque it correctly -_-
    #11
  12. Tyeler18
    Tyeler18 Proven Member
    Dec 16, 2008
    1,948
    23
    Casa Grande, Arizona
    Pretty common for people to torque the hell out of them when installing.
    Thanks for reminding me my 3g still needs new spark plug tube seals. The oil fills the cylinder so much that it pops the plug wires out. ROFL
    #12
  13. jmkhet
    Feb 11, 2008
    31
    Lowell, Michigan
    Glad you found the problem.
    Hmm...only reason i posted up all that other info. was because the guy asking the question on why hes getting oil in the plug well had a 97 GST.My apologies if anything on there didnt pertain to the 4g63t.
    #13
  14. arturorz
    arturorz Supporting Member
    Nov 5, 2010
    52
    Orlando, Florida
    Hey, don't feel bad.
    I had your exact same problem about 1 month ago.
    The only difference is that it was me who barely put too much torque, if any, and cracked the valve cover. :banghead:
    And yes, I had to tight them because they were loose too.
    There's always a few for sale on the classifieds.
    #14
  15. theslab
    theslab Proven Member
    DSM Profiles:
    Sep 14, 2010
    100
    gurnee, Illinois
    striped bolts holes can cause it too i have he same problem right now. the previous owner overtorqued the bolts and striped the bolt holes on the head. You can clearly look and see oil coming out of the bolts.
    #15
  16. leecastillo
    leecastillo Proven Member
    DSM Profiles:
    Oct 3, 2009
    35
    Orlando, Florida
    #16
  17. 19Eclipse90
    Sep 29, 2003
    4,028
    352
    OKC, Oklahoma
    I feel like I've seen this before... what, less than 10 posts previous in this same thread?
    As I said before, not all of this is applicable to DSMs or the 4G63 engine. A bad head gasket, bad valve stem seals, or worn out valve guides will not cause oil to leak into the spark plug wells or onto the spark plug valley on the valve cover in the 4G63. These items will cause leaks into the combustion chamber, an area very different from the one discussed here. On the other hand, valve cover gaskets will not cause an oil leak into the combustion chamber.
    #17
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
