buddy3824
- 120
- 0
- Mar 31, 2009
lexington,
Kentucky
ive been trying to figure where ive been having a bad oil leak from, it was pretty bad, but i noticed that it wasnt bad at all under "normal" driving conditions. but when i give a hard pull, i can smell the oil spewing onto the exhaust, to give an idea on how much oil is spewing out, my whole underbody is covered in it all the way back to my fuel tank.
before i get to elaborate, i know I have had excessive crankcase pressure before all this because i was blowing my dipstick out. i have since put an oil catch system and replaced the pcv valve. obviously that had no fix to the problem I guess that matter should be in a different thread, but any tips there are appreciated.
So... back to the oil leak.. i had noticed that the oil was coming from the crank area (oil was evident on crank pulley) so i cleaned off the area and took for a test drive just to verify and there it was.. So surely i had a crank seal leaking. ehh no biggie i thought. Well, today i had the day off from work so i decide to go ahead and tear into the issue, and when i get in there, i see that the oil is not coming from that area! i look up at the TB tensioner and it is just flooded with oil and my timing belt is soaked, but my camshaft areas are clean. Soo, this puzzles me, the only way that oil can get up on the tensioner bracket would be if it was squirted from the top part of front case seal correct? or am i mistaken? now would this mean that mean front seal is broken? i mean, arent those just paper seals.. this is the first time that i have teared into a dsm this far so if i am mistaken on something. please point me in the right direction and around my newbness
