Please Support Morrison Fabrications
2G Oil Leak, Not Sure What
Ferp
159
14
Sep 14, 2014
Edmonton, Alaska
I initially thought I had a head gasket leak but after getting the car up on jacks and checking to see if my oil/coolant had mixed I had confirmed it wasn't a gasket leak. So the oil is leaking out near the headers (not really sure what they're called in a turbo application) and I have no clue what it is. Maybe cam seals?
Cam seals leak into the timing belt area. Not sure on the 2Gs but 1gs can develop a leak around the center exhaust manifold bolt. I would "guess" valve cover gasket as most likely.
The 1G center exhaust mani bolt goes into a water passage on the head. Have mine apart and in front of me right now so you would see coolant from that if it was leaking. I would guess valve cover too.
The 1G center exhaust mani bolt goes into an oil passage on the head. Have mine apart and in front of me right now so you would see oil from that if it was leaking. I would guess valve cover too.
Fixed, like SrKegler said. And it's something found on all 4G63 DSM heads.
