oil leak driver side
Posted by crazyquik22023, Apr 2, 2010
Please Support Race Components Inc
  1. crazyquik22023
    crazyquik22023 Proven Member
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    I have a oil leak that i cannot pinpoint. it it coming from the drivers side by the oil pan but it is not the oil, not from the OFH, and not from the turbo. it drips down onto the side of the oil pan and the drips off the oil pan. any ideas???
    Log in/Register to remove ads
    My DSM:
    1998 Mitsubishi Eclipse GST
    12.900 @ 115.000 MPH
    Loading...
  2. dsm8883
    dsm8883 Proven Member
    206
    Joined Dec 19, 2004
    gainsville, Florida
    clean it and add oil dye.
  3. crazyquik22023
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    ya i can't even see where it would be coming from though so that wouldnt really help
    My DSM:
    Loading...
  4. ReYnd
    ReYnd Proven Member
    323
    4
    Joined Dec 8, 2009
    Deep Water, West Virginia
    I have a leak in the same spot. It's coming from the area where the oil pan meets the oil pump/front cover gasket, leading me to believe it's the gasket for the latter. Or maybe even the oil pan sealant gave up, because I also have high oil pressure. If your balance shafts have been deleted, check your oil filter housing for the enlarged relief hole. High pressures will kill gaskets in a hurry, anywhere they can.
    PS. Post pics if you pin-effin'-point where yours is leaking, I haven't had a chance to tear into mine yet, and it wears on my sanity to consider everything it could be.
  5. blackAWDTALON
    blackAWDTALON Probationary Member
    9
    Joined Mar 9, 2010
    Muskegon, Michigan
    I had the same problem.... ended up being the damn valve cover was cracked
  6. thirsty
    thirsty Proven Member
    77
    15
    Joined Oct 4, 2008
    Brisbane, Australia
    G'day,
    When you say drivers side, is that the side where the belt drive for the cams and the oil pump are. If so my bet would be the oil seal on the crank. It will leak after a while from the extra pressure in the sump from blow-by under boost.
    Cheers
    Ross :thumb:
    My DSM:
    Loading...
  7. lyonswm
    lyonswm Proven Member
    34
    Joined Feb 8, 2010
    Bennett, Colorado
    I also have an oil leak on the same side and if i leave the car idling for a while it will continue to drip and leave a small puddle of oil. I can tell it is coming from the top becasue the oil goes pretty high up. I took off my cam gear cover and looked around the camshaft seals and sure enough there was oil around them. So for sure check the camshaft seals. :thumb:
    Loading...
  8. tsi1991awd
    tsi1991awd Proven Member
    1,309
    4
    Joined Sep 28, 2008
    Puyallup, Washington
    I have a leak where the oil pan meets the block. The idiots that rebuilt the motor didnt use an oil compatible gasket maker and it leaks bad. I can see it seep and flow down toward the OFH. It caused the timing belt to get soaked with oil. The valve cover is also cracked at the spark plug well so it is leaking oil from there as well.
    But if you dont see oil in either of those areas, take the upper timing cover off and see if there is oil around the cam seals. If not, it is probably from the front case.
    My DSM:
    Loading...
  9. crazyquik22023
    610
    5
    Joined Sep 14, 2008
    Akron, Ohio
    it's not from the oil pan gasket, not from the valve cover... idk about the cam seals and it very well could be the crank case... hope i can find it.
    My DSM:
    Loading...
  10. turbotalon31
    turbotalon31 Proven Member
    291
    3
    Joined Jan 9, 2010
    reading, Pennsylvania
    Aa dsm8883 said put some dye in the oil drive it and im sure it will glow when u put the light on it. used this to find many leaks works well and is pretty cheap.
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
