kilo4
Supporting VIP
- 276
- 4
- Apr 26, 2009
Fairfield,
California
I've been having clutch disengagement problems for some time. I've pretty much replaced the entire drive train. Every parts listed below has than 200 miles. I finally gave up and replaced the after market clutch master and slave cylinder. I figured it must be good, since it's lifetime warranty. I took it apart and compared it to the OEM parts I received from STM. The OEM parts in the photo is from a used OEM part but it's exactly the same dimensions from the new unit I received from STM. I was surprised to see the difference, see the attached photo's. The master cylinder was purchased at Vaca autoparts (made in Japan) and the slave was purchased at Autozone (made in Taiwan).
Problem:
Hard to shift from 1st to 2nd gear above 3K rpm, hard to go in 5th and reverse gear
Solution:
replaced after market clutch master and slave cylinder. Also installed the SPEED BLEEDER 10 x 1.0 mm from Summit Racing part# RUS-639560 (made bleeding a breeze) = 100 % air free
Parts replaced:
- Jacks tranny w/transfer case
- Sheptrans pedal assy
- OEM shift cables
- STM shifter bearings
- OEM shift bracket bushings
- rebuilt OEM tranny cable select assy (bushings and pad)
- bushings under shifter plate assy
- OEM tranny fluid
- After market clutch master cylinder (at first)
- After market clutch slave (at first)
- rebuilt drive shaft (might as well)
- switched to 4 bolt rear with rebuilt axles (might as well)
1st Photo:
- Aftermarket master cylinder left--OEM on right
2nd Photo:
- master cylinder internals aftermarket on left and OEM on right
- notice the difference on the seal location (about 10 mm further back, therfore the aftermarket pushes smaller volume
3rd Photo:
- aftermarket master cylinder adjustment rod lenght (71.35 mm)
4th Photo:
- OEM master cylinder adjustment rod lenght (71.92 mm)
5th Photo:
- OEM slave (top)
- aftermarket slave (bottom) = *same diameter, different springs, different design but close
Problem:
Solution:
Parts replaced:
- OEM shift cables
- OEM tranny fluid
1st Photo:
2nd Photo:
3rd Photo:
4th Photo:
5th Photo:
- OEM slave (top)
