2G No Start Condition
Posted by TunedUp, Mar 18, 2017 at 1:54 PM
Maintenance & Repairs - Oil choices, timing belt, setting timing, CV boot replacement, alternator servicing, fuse/relay checks, and other basic maintenance, repair and diagnosis discussions.
Please Support Kiggly Racing
  1. TunedUp
    TunedUp Proven Member
    DSM Profiles:
    Dec 28, 2011
    132
    9
    Panama CIty, Florida
    Okay so I read through, and tested everything that I feel pertains to my situation from http://www.dsmtuners.com/threads/how-to-diagnose-a-no-start.217951/ . My starter, starter relay, and everrything is getting power to it. When I turn the key the fuel pump turns on the relay clicks, but the starter doesn't do anything. The starter is getting power so at this point i don't know what is going on. I went through the FSM and tested everything the way it says, but it didn't say anything about diagnosing a no start with the ignition wiring. I feel that is what is causing this but don't know where to start. Any help is appreciated!
    #1
  2. Dave2g
    Dave2g Probationary Member
    DSM Profiles:
    Mar 14, 2017
    10
    4
    Poughkeepsie, New_York
    It sounds silly but bang your starter with a crowbar or breaker bar. In Florida I doubt it would freeze up but I had a no start issue on my supra that I couldn't fix for the life of me. And it turns out the starter was broken, so I got a used one and it wouldn't work until I banged it a few times. Did you just put the car together? Starters in my experience are very delicate creatures and don't like being manhandled or dropped. It only makes sense to me that the problem lies with the starter, but I very much could be wrong.
    #2
    93AWDDSM likes this.
  3. TunedUp
    DSM Profiles:
    Dec 28, 2011
    132
    9
    I'll go try that and to answer your question I did just put it back together over the last week so you never know. I did jump the starter with a screw driver and it worked as it should but I turn the key to start and nothing happens so I am going crazy.
    #3
  4. Dave2g
    DSM Profiles:
    Mar 14, 2017
    10
    4
    Does the starter relay have multiple prongs to put the positive and negatives to? Switch up where you are putting them and see if that fixes it. On my E30 the starter relay has 4 prongs and I had to switch them a few times. If you have a reman starter thats most likely the case, they have two dud prongs. If that doesn't work, then I've got nothing haha. Sorry man, it's always the worst when you spend so much time putting something back together only to find the dumbest thing holding you back. You'll get it, don't give up.
    #4
  5. TunedUp
    DSM Profiles:
    Dec 28, 2011
    132
    9
    Okay tried banging on it did nothing. The starter looks fairly new, but I have no idea whether it's reman or not. Thank you for the encouragement this is literally the only thing stopping the car from running to go get the exhaust welded and dial in the tune for this hx40.
    #5
  6. TunedUp
    DSM Profiles:
    Dec 28, 2011
    132
    9
    What sensors not being plugged up or bad would cause a no start?
    #6
  7. gst-turbo
    gst-turbo Proven Member
    DSM Profiles:
    Nov 7, 2012
    541
    40
    Petaluma, California
    Try taking it to autozone they check it for free. It might just be bad.
    #7
  8. stiggity99
    stiggity99 Proven Member
    DSM Profiles:
    Mar 31, 2011
    163
    York Haven, Pennsylvania
    tunedup:
    i experienced the same issue after my first build. turned out the starter wasnt grounded correct. try running a battery wire off the negative terminal, too one of the main starter bolts. right there at the bell housing....
    #8
  9. jakk220
    jakk220 Proven Member
    DSM Profiles:
    Nov 13, 2010
    527
    47
    Stow, Ohio
    +1 on the starter ground. Make sure that it is grounded well. I have experienced the same thing with a bad starter ground. Also check your clutch switch.
    #9
  10. gsxeclipse102
    gsxeclipse102 Proven Member
    DSM Profiles:
    Mar 8, 2003
    339
    64
    carmel, New_York
    If you jump the starter with a screwdriver and it cranks over then the ground is ok and the battery feed is good. The problem is no power to solenoid from ignition switch. Starter check is simple. You need constant voltage at the big wire and switched voktage at the small wire. Possibly left a connector unplugged?
    #10
    93AWDDSM and Dave2g like this.
  11. Dave2g
    DSM Profiles:
    Mar 14, 2017
    10
    4
    This this this this. Check those solenoid wires. Good luck man!
    #11
  12. jakk220
    DSM Profiles:
    Nov 13, 2010
    527
    47
    Stow, Ohio
    That is not entirely true. When we first got my girlfriends 1g it would not start via the ignition. I took the ground wire and hooked it to a jumper cable to get some extra length and grounded it to the hood latch. Started every time. Grounded anywhere else it would not start UNLESS I bridged the starter with a screw driver. If I did that it would work no matter where it was grounded. Really weird. But it happened. I do not remember what I ended up doing to fix it but I did find a permanent fix as it hasn't given me trouble since.
    #12
  13. Brembo
    Brembo Proven Member
    DSM Profiles:
    Aug 17, 2014
    42
    6
    Clifton, New_Jersey
    I agree. Have some one crank the car and you check for power on solenoid wire. You just answered you own question when you mention the screw driver. Follow that wire. Also make sure you don't have some cool magic mad JDM alarm that kills the power so the solenoid. Good luck and post back.
    #13
  14. jim95redgsx
    jim95redgsx Proven Member
    Jan 26, 2005
    70
    31
    Riverhead, New_York
    Try unplugging the starter disable switch on the clutch pedal.
    There is a one wire (black/yellow wire) connector that runs between the main engine harness and the starter harness. It is located behind and below the thermostat housing. This wire carries the start signal from the starter relay (under the dash) to the starter solenoid (on the starter). Here's a pic:
    http://www.dsmtuners.com/threads/2g-engine-bay-electrical-connections.298047/page-2#post-151542290
    If this connector is unplugged, you won't get any start signal to the starter.
    Jim
    #14
  15. 93AWDDSM
    93AWDDSM Proven Member
    DSM Profiles:
    Jan 1, 2009
    594
    12
    Vancouver, Washington
    Not sure if this pertains to a 2g but when I did my tranny, pulled starter and all that stuff. Got it all back together and the car had power. Lights, gauge cluster but wouldn't start.. checked for clean ground then jumped with a wire for starter and it started but wouldn't start if shut off. Silly me, forgot the connector under the battery tray area going to the starter :( heh went over everything found it and perfect.
    The taping the starter isn't a bad idea, it has happened to my previous awd dsm, got home one night and next morning to leave for work and no starter but had power. That time I tapped it with my extension bar. Good as new till the parts stores.
    @jim95redgsx haha, perfect you explained the connector he might have missed.
    #15
  16. TunedUp
    DSM Profiles:
    Dec 28, 2011
    132
    9
    Man I love this community! I got it resolved the solenoid was bad I tried grounding the thing anywhere and everywhere finally gave up and took it to O'reillys and sure enough the solenoid was bad. I got so lucky though that they actually had one in stock. Thank you to everyone y'all were a huge help in this. Now that I got it started noticed a crack in the radiator, and my 90* -4an elbow for my feed line was cracked so it leaked oil everywhere. Happy I got it started just got to buy a new fitting now and a radiator :(
    #16
    gsxeclipse102 and 93AWDDSM like this.
  17. Brembo
    DSM Profiles:
    Aug 17, 2014
    42
    6
    Clifton, New_Jersey
    Good to hear she is running. One issue tackeled next one inline. Good luck.
    #17
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
