1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
No start cold starts fine warm. Pics included
Posted by jokerzlife, Dec 4, 2018
Please Support Kiggly Racing
  1. jokerzlife
    jokerzlife Proven Member
    32
    Joined May 5, 2009
    cut bank, Montana
    Hi just got the car finally got below freezing and the car won’t start. It was 24 degrees Fahrenheit out when I took the photos. ignition on not running. I don’t know a lot about these cars but I am a somewhat educated mechanic. Just not completely sure what I’m lookin for.
    Log in/Register to remove ads
    My DSM:
    Loading...
    Featured Products from our Supporting Vendors
  2. ErikTande
    ErikTande Proven Member
    774
    170
    Joined Dec 17, 2012
    Centennial, Colorado
    Replace your coolant temp sensor.
    My DSM:
    1997 Eagle Talon TSi AWD
    Street Build
    T25   manual
    Loading...
  3. jokerzlife
    32
    Joined May 5, 2009
    cut bank, Montana
    K ordered the coolant temp sensor was like 27$. They asked if it was a Mitsubishi motor or Chrysler I said Chrysler but I’m Not sure. how do you tell if there is a difference or if it even matters. If I’m mistaken the 420a was the Chrysler motor but they also asked if it was turbo’d so I don’t know if they got the right one sent.
    My DSM:
    Loading...
  4. Kryndon
    Kryndon Proven Member
    220
    63
    Joined Jan 10, 2014
    Bulgaria, Europe
    Right off the bat, if you have an AWD, that means it's a turbo. And if it's a turbo, that means it's got the Japanese 4G63. The coolant temp sensors for those are fairly cheap, but depends on the brand.
    The 420A is the Chrysler engine, correct, but that only comes naturally aspirated (without turbo).
    My DSM:
    Street Build
    14.769 @ 92.22 MPH
    Loading...
  5. jokerzlife
    32
    Joined May 5, 2009
    cut bank, Montana
    Ok I swapped out the sensor and it still don’t start. :/ guess I’ll start with fuel pressure and work froM there.
    My DSM:
    Loading...
  6. jokerzlife
    32
    Joined May 5, 2009
    cut bank, Montana
    Found out previous owner gapped the spark plugs to .048. Fixed that starts up good now. Thanks for the help everyone.
    My DSM:
    Loading...
    Kryndon likes this.
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
