Please Support STM Tuned
2G No power to fuel pump
Layne97gst
Jun 13, 2018
north zulch, Texas
I have a 1997 mitsubishi eclipse gst 2 liter turbo that's a manual, that I just put a new alternator on,it has crank and air but no power to fuel pump but all fuses are good and lighting up so what could it be
Hey how are you checking power to the fuel pump? I might be wrong, but I think on these cars the pump only activates while engine is cranking. It does not "prime" with just ignition switch on like other vehicles. Thank you for your time, Jason Penny
The ECU controls the fuel pump. When it wants the pump on it pulls the signal line from the fuel pump relay to ground. That causes the relay to switch on and power the pump.
I've seen people blow the transistor on the ECU that switches the signal by jumpering the wrong pins on the relay or ECU with 12v. Normally the resistance of the relay coil protects the transistor.
Get out the multimeter and start checking the circuit. It will be clear in short order where it's failing.
