xRichieRich07x
- 151
- 0
- Apr 26, 2006
White Oak,
Pennsylvania
Just out of curiosity, what would my car show symptoms of if the pcv valve was broken or clogged? (On a n/t)
Note: This feature currently requires accessing the site using the built-in Safari browser.
It's for emissions. Your crankcase has vapors that need to get bled off. The PCV releases these gases that build up. If you have a catch can and a breather, then you can vent these to the atmosphere. The PCV is a one way only valve that allows these built up gasses to escape the crankcase when the system is in vaccuum. When you build boost, it does not bled off the vapors, and the valve closes so that your compressed air does not enter the crankcase. It's worth the $6.
Edit: Opps. You have a N/T. Didn't see that. It's still worth the small amount of money. The vapors are burned in the combustion process. Keeping these gasses trapped in the crankcase is not good.
Couple of ideas.
The owner could have over tightened it before you and put a hairline crack in it. Then when you tightened it in by hand you could have had the threads bottomed out and you putting the wrench on it could have just snapped it off.
If im not mistaken the threads for the pcv valve are slightly angled and you could of cross threaded it in.
I personally would not buy a used valve cover off ebay. Thats just me.
