*New Release* Boostin Performance 1,000+WHP Red Demon Spec Short Block (DSM/Evo)
Posted by Boostin Performance, Feb 27, 2016
Please Support Extreme Turbo Systems
  1. Boostin Performance
    Boostin Performance Supporting Vendor
    209
    205
    Joined Jan 7, 2014
    Hoffman Estates, Illinois
    If you're looking for a short capable of handling 1,000 WHP, look no further we have the answer: www.BoostinPerformance.com/Demonspec
    Our 'Red Demon Spec' Short Block package has powered our shop car, the Red Demon, to (10) 7-second 1/4 mile passes, the latest being a 7.46 E.T. and breaking the 200 MPH barrier in the quarter! This short block package has also propelled this car to an astonishing 213MPH in the 1/2 mile. This Red Demon Spec motor has lasted 2 full race seasons at this power level (1165 WHP on Mustang Dyno), so we can assure you that this motor has been put through extensive testing.
    Our Red Demon Spec Short Block is a 2.0L Long Rod / High Revving Short Block Package. By improving the rod ratio, there is less side loading on the cylinder walls. The connecting rod also transfers power to the crankshaft at a more optimal angle, when compared to a standard 2.0L. The Aluminum rods come fitted with L19 rod bolts, and high compression gas ported pistons are attached via custom 1,500 HP wrist pins. We also machine the block to be used with our Boostin Performance 1/2" L19 Head Stud Kit (sold separately).
    We recommend fully filling the block to reinforce the cylinder walls. If you have a standard bore block and want to drive it on the street, the 1/2 fill option is for you, allowing for use of the factory water pump.
    We also offer a copper head gasket option, which we highly recommend for fully filled blocks, and for race motors. The block and head are machined with the O-ring & Receiver groove to offer the ultimate seal when used with our copper head gasket. Included with this option is machining the block, and a custom copper head gasket.
    This head gasket option requires you to send us your cylinder head - this is an additional cost not included with this Red Demon Spec Short Block package.
    Watch a video of a customer's car making 1000 horse power with a Red Demon Spec Short Block:
    Watch a few 7 Second passes:
    Take a ride in a 7 second car ;) :
    Log in/Register to remove ads
    My DSM:
    1996 Eagle Talon TSi AWD
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  2. Archer Fabrications
    Archer Fabrications Supporting Vendor
    5,965
    702
    Joined May 9, 2011
    Scottsdale, Arizona
    I was thinkin ng anout sending you guys my block for a stage 3, this looks like an awesome package, but I'm personally not ready for aluminum rods.
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Drag Race Build
    11.128 @ 132.5 MPH
    Loading...
  3. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    No problem, we can build you one with a steel rod. ;)
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  4. Archer Fabrications
    5,965
    702
    Joined May 9, 2011
    Scottsdale, Arizona
    I'll be ready late april or may. Do you guys prefer a completely stripped block and include crank? My block is already .020 over but the walls look good. Just ran the motor dry when oil filter soun off so I'm upgrading everything, is wiseco your go to piston? Or do you guys have anything good/bad to say about ross? Want the motor to be good for all a 6466/6766 can throw at it at a 9k rev limit drag car/weekend street warrior down here in phoenix, i just moved down here and dont know any machinists I'd trust so i figure why not send it to one of the best.
    My DSM:
    Drag Race Build
    11.128 @ 132.5 MPH
    Loading...
  5. mountainbike91
    mountainbike91 Proven Member
    504
    77
    Joined Feb 18, 2010
    stony brook, New York
    what brand pistons are those?
    My DSM:
    Drag Race Build
      automatic
    Loading...
  6. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    You can send us your short block complete or bare, it doesn't matter.
    All our short blocks are equipped with a Boostin Spec Piston, and a Boostin Spec I-beam Rod unless you opt for a Red Demon Spec short block which is equipped with aluminum rods.
    Let us know when you're ready. :)
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  7. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    Boostin' Bump!
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  8. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    Bump! Give your ride the ultimate engine upgrade!
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  9. doghouse
    doghouse Probationary Member
    13
    3
    Joined May 7, 2015
    Kingston, Florida
    That car is a work of art
  10. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    Thank you! :)
    TTT!
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  11. dsmftw4g63t
    dsmftw4g63t Probationary Member
    Joined Jul 11, 2016
    Marion, Indiana
    how can I send in my block and head to get them machined
  12. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    Please send us over an email, and we can discuss the options. Thanks!!
    boostinperformance@gmail.com
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  13. hollywood_ikr
    hollywood_ikr Proven Member
    203
    6
    Joined Jan 17, 2006
    el paso, Texas
    Just wanted to thank you for providing world class parts and service for our aging cars. Little by little shops have been deserting us for newer and more profitable platforms and it's great to see you guys supporting and smashing records!
    My DSM:
    1998 Mitsubishi Eclipse GSX
    Street Build
    GT40   manual
    Loading...
    95talongirl likes this.
  14. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    You're welcome and thank you for the support! After all, without your support, we wouldn't be able to offer these packages! :)
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
    NCjoey likes this.
  15. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    Motor Monday Bump!
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  16. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    Boostin' Bump!
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  17. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    TTT!!
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  18. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    Post-shootout bump!
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  19. dk7868
    dk7868 Proven Member
    34
    4
    Joined Mar 15, 2016
    Clarksville, Tennessee
    OMG..I need to win the lottery:cry:
    My DSM:
    1997 Mitsubishi Eclipse GST
    Street Build
    T25   manual
    1995 Mitsubishi Eclipse GST
    Street Build
      manual
    Loading...
  20. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  21. 93AWDDSM
    93AWDDSM Proven Member
    836
    39
    Joined Jan 1, 2009
    Vancouver, Washington
    Amazing.....
    My DSM:
    1992 Eagle Talon TSi
    Street Build
    16g   manual
    Loading...
  22. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    :thumb:
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
  23. Vegas smith
    Vegas smith Proven Member
    1,636
    641
    Joined Dec 2, 2002
    Houston, Texas
    Yeah but does Boostin have any results to back up their shop?
    My DSM:
    1993 Eagle Talon TSi AWD
    Street Build
    16g   manual
    1992 Eagle Talon TSi AWD (sold)
    16g   manual
    Loading...
  24. Boostin Performance
    209
    205
    Joined Jan 7, 2014
    My DSM:
    Drag Race Build
    7.37 @ 205 MPH
    Loading...
    Slowmaro23 likes this.
  25. Tanro
    Tanro Proven Member
    1,413
    47
    Joined Jul 22, 2009
    Hanceville, Alabama
    Are you serious right now?
    My DSM:
    1999 Mitsubishi Eclipse GST
    Street Build
    16g   manual
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory
