badbird
- 47
- 0
- Nov 15, 2013
Little Rock,
Arkansas
Alright guys, I have a few questions, any knowledge helps. After searching I cannot seem to find an adequate answer to my questions, and well as for shops out there, they obviously want to make money from trans rebuilds and won't give me a direct answer.
I have a 1990 awd turbo Eagle Talon, 5 speed trans and 123k original miles. I had a strange tick noise whenever I would pull hard in WOT in upper RPMs for a few days. After determining it was not rods or lifter tick making the noise as thought, I went to checking suspension issues. To my dismay I smelled what appeared to be transfer case fluid and or trans fluid... I parked in the garage that night and while rolling into the garage I heard somewhat of a cracking noise. I started to see a small 6 inch puddle form underneath the trans and transfer case and went to determine what it was leaking. It appears the AWD trans case end cover (http://www.jackstransmissions.com/collections/misc/products/awd-case-end-cover) as seen in that link has appeared to crack at the top. From my understanding the 5th gear synchro bolt or end nut bolt, not sure which gets loose and hits the cover and cracks it.
I called Jacks trans and they said they recommended a rebuild, which may be the case, however aside from the fact of never rebuilding a trans, me and my family are pretty good mechanics and the understanding of them. If I can just replace something small and the end cover to the trans, this would obviously be best for me and my budget currently. The transfer case and trans were shifting great while driving it home, fluid maybe lost like I said, a six inch puddle and have not driven since.
Anyone have any advice or dealt with a similar situation?
Thanks so much for any help,
Jordan
Jordan
