Please Support ExtremePSI
ECUflash Need to change maf size in ecu flash?
bw2277
48
Mar 18, 2013
north bend, Oregon
I have tried searching for this issue with nothing found so...my question is im running a 3" gm maf and tuning with ecu flash, do I need to adjust my maf size or scaling table using it in blow thru setup?
Hate to revive an old thread but can anybody answer this still? I'm running a 3" GM Maf with a MAFT in a blowthru setup. The MAFT is configured just on a basic level with my AUX=4 and BASE=2 for my stock 450cc injectors. Do I need to edit the MAF size in ECUflash from what it's originally at being 286g/s? Also do I need to edit the scaling or smoothing table at all?
That’s what I think. As long as the MAFT is set up to stock settings I think ECUflash will see it as a stock MAF size. Just wanted some confirmation.
