- Thread starter
- #26
SasaniFab
- 2,433
- 782
- Dec 1, 2013
Mexico,
Connecticut
Can't upload pics for some reason , try later. Thanks guys for your help, it's appreciated
Note: This feature currently requires accessing the site using the built-in Safari browser.
Now I see why people don't bother rebuilding the transmission themselves. Finding parts is becoming a problemWhen you finally get to the point of putting the cases back together (all gear clusters, everything inside), make sure you use the solder method (described in the FSM) to figure what spacers (shim) you need to get proper preload/endplay. Don't do this and your entire rebuild can be for nothing (popping out of gear is typical end result after a few months). Most local tranny shops won't do this due to the extra time it takes and proper spacer unavailability (or they put in the wrong spacer because they don't have the correct one so it works only for the warranty period - I have personal experience on this). {Don't use solder that expands: http://www.dsmtuners.com/threads/f5m33-rebuild-dsm-fwd-transmission.317077/#post-151770831.} And make sure you replace all the main tapered and ball bearings even if they look ok (they get worn). And any worn syncros/hubs/sliders/keys. And reverse idler gear if teeth are rounded (won't go into reverse without letting clutch out slightly). And worn forks (won't go in gear or can pop out immediately while shifting). And check for worn interlock plate bolt. Also on shift levers the Select Lever Shoe gets worn (won't easily go into selecting gear pair 1-2, or 3-4, or 5-R from another gear pair). Here's a great rebuild guide even though it's for a 2g: http://web.archive.org/web/20100627174759/http://www.twingles.com/ideck/rebuild3/dretranny.htm.
Seems like something you could have made reasonably cheap with a lathe if you had all the measurementsTwicks69 (tranny rebuilder) has some parts he may sell you. He bought up all the spacers (shims) so that's where I got mine.
