jon2manyrides
- 46
- 0
- Aug 15, 2014
carlin,
Nevada
Manley Performance Mitsubishi 7-Bolt 4G63 Stroker Rotating Assembly (2.3L Stroker): 100mm Stroke Crank w/150mm Rods Manley Performance Mitsubishi 7-Bolt 4G63 Stroker Rotating Assembly (2.3L Stroker): 100mm Stroke Crank w/150mm Rods
SKU: MAN-4G63-100mm/150mm
Crank: Forged 190120
Rod: 150mm 300M I-Beam 15403-4
Rod Bearing: ACL Race "Tri-Metal"
Main Bearing: ACL "Tri-Metal" 97-99 7-Bolt & EVO VIII & IX
Piston: 87mm/9.0:1 CR 608020C-4
FIC BlueMAX 1450cc Peak and Hold/Low Impedance Ball & Seat Injectors: Mitsubishi Eclipse 90-99 FIC BlueMAX 1450cc Peak and Hold/Low Impedance Ball & Seat Injectors: Mitsubishi Eclipse 90-99
SKU: FIC-IS126-1450
Spark Tech Coil on Plug System: Eclipse 1997-99 Plug & Play Unit Spark Tech Coil on Plug System: Eclipse 1997-99 Plug & Play Unit
SKU: STI-COP-DSM9799PP
JM Fab "Race Version" Sheetmetal Intake Manifold : Mitsubishi Eclipse 95-99 JM Fab "Race Version" Sheetmetal Intake Manifold : Mitsubishi Eclipse 95-99
SKU: JM-2G-INTA-01
2G OEM Map Sensor Mount: Selected
Additional Injector Bungs: None Selected
Extra Vacuum Port (4 standard): None Selected
NOS Bungs: None Selected
Polished: Selected
Throttle Body Flange: 2G Stock '95-'99
Forced Performance "BLACK" Ball Bearing Turbocharger: Mitsubishi Eclipse 90-99 Forced Performance "BLACK" Ball Bearing Turbocharger: Mitsubishi Eclipse 90-99
SKU: FP-NTDSMFPBLACKBB
Wastegate: Wastegate on O2
Compressor Cover: 84mm Inlet
Turbine Housing: 8cm2 Housing
Oil Return Line: Selected
Punishment Racing SS 44mm Ext. Atmosphere O2 Housing: Mitsubishi Eclipse 90-99 Punishment Racing SS 44mm Ext. Atmosphere O2 Housing: Mitsubishi Eclipse 90-99
SKU: PR-DSM-O2MVRAT
TiAL MV-R Wastegate: 44mm V-Band TiAL MV-R Wastegate: 44mm V-Band
SKU: TL-MVR-SL
ACT Xtreme Street Clutch Kit : Mitsubishi Eclipse 90-99 Turbo ACT Xtreme Street Clutch Kit : Mitsubishi Eclipse 90-99 Turbo
SKU: ACT-MB1-XTSS
Quaife ATB Helical Limited-Slip Differential (Center): Mitsubishi Eclipse 92.5-99 AWD Quaife ATB Helical Limited-Slip Differential (Center): Mitsubishi Eclipse 92.5-99 AWD
SKU: QFE-QDH9B
Mishimoto X-Line Performance Aluminum Race Radiator: Mitsubishi Eclipse 95-99 Mishimoto X-Line Performance Aluminum Race Radiator: Mitsubishi Eclipse 95-99
SKU: MM-RAD-ECL-95TX
DriveShaft Shop "HD" Aluminum Rear Shaft 1000HP: Mitsubishi Eclipse 95-99 AWD DriveShaft Shop "HD" Aluminum Rear Shaft 1000HP: Mitsubishi Eclipse 95-99 AWD
SKU: DSS-MISH2-HD
DriveShaft Shop Level 2 650HP Front Axles: Mitsubishi Eclipse 95-99 AWD DriveShaft Shop Level 2 650HP Front Axles: Mitsubishi Eclipse 95-99 AWD
SKU: DSS-RA9827L2/RA9828L2
DriveShaft Shop Level 2 650HP Rear Axle Bar : Mitsubishi Eclipse 95-99 AWD DriveShaft Shop Level 2 650HP Rear Axle Bar : Mitsubishi Eclipse 95-99 AWD
SKU: DSS-MIR3-ABS
Snow Performance Stage 3 Boost Cooler Kit: All Models *SALE!* Snow Performance Stage 3 Boost Cooler Kit: All Models *SALE!*
SKU: SP-20100
Walbro 255 LPH with Install Kit: Mitsubishi Eclipse 95-99 Walbro 255 LPH with Install Kit: Mitsubishi Eclipse 95-99
SKU: WAL-317-847
Mishimoto Fan & Aluminum Shroud Kit: Mitsubishi Eclipse Turbo 95-99 Mishimoto Fan & Aluminum Shroud Kit: Mitsubishi Eclipse Turbo 95-99
SKU: MM-FS-ECL-95T
Extreme PSI Oil Cooler Kit: Mitsubishi Eclipse 7 Bolt *SALE* Extreme PSI Oil Cooler Kit: Mitsubishi Eclipse 7 Bolt
SKU: PSI-7BOCKIT-SS-BK
well thats a parts list gonna start in the spring. block is coming out next week and heading to machine shop for head work and what nots... any input would be great, i heard the fp black is good for 650hp which is what im pushing for at the wheels... i know there are little odds and ends i dont have listed but i kinda know what i need. this is going to be a full build. at the moment i am test fitting a roll cage and cross braces. its going to have a full interior with stereo. i think its a good start i am planning on running 9.0-1 compression WITHOUT NOS. im trying to push this car into the 10.**'s in the quarter mile. i already have suspension parts installed, i have big plans with this car its gonna be show and go best of both worlds... it doesnt need to run 8's or anything but i want it to be feared and respected on the streets... couple EVO guys giving me crap cause they bought fast cars and i build them .. they say its a waste and i should get rid of the car and buy something worth driving... i am still new to the dsm world but iknow my way around a wrench and have built alot of cars in the past... so i dont need any haters or people telling me im stupid this is going to be a no holds bar build no expense spared... im looking for help to make my GSX a rocket ship...
SKU: FIC-IS126-1450
SKU: JM-2G-INTA-01
Polished: Selected
SKU: PR-DSM-O2MVRAT
SKU: TL-MVR-SL
SKU: ACT-MB1-XTSS
SKU: QFE-QDH9B
SKU: DSS-MISH2-HD
SKU: DSS-MIR3-ABS
SKU: SP-20100
SKU: WAL-317-847
SKU: MM-FS-ECL-95T
