LunarTerror
- 0
- May 27, 2018
Greensburg,
Kentucky
I just got my DSM Saturday and I went to pass someone on the way to work and a mist blew out the side of the engine bay. Now it won't stay running and idles rough. I had to pull of the side of the road because I lost most of my power. When I use the accrlerator it revs up a little for a second then goes back to idling at 100 or less RPM and dies. It also has black smoke coming out of the exhaust. The only code I have is for the Engine Coolant Temperature Sensor which I have ordered a replacement for already. It is a 1995 Eagle Talon TSi AWD. It has a 1997 eclipse gsx motor in it. AFPR sits at 3-5 PSI when not running after this and when it runs at 100 or less RPM it sits at about 40 PSI and it's fluctuating about 1-2 PSI. It also has a 16g turbo running 16 PSI.
