blcknspo0ln
DSM Wiseman
- 7,773
- 95
- Jul 31, 2003
Central,
New_Jersey
I'm so lost and I have no clue why? here's a pic of my autometer cobalt electric short sweep gauge. I have an oil pressure and a water temp that need to work correctly.
Top left is +12V, which goes to any power source that gets 12V when KEY ON
Top right is ground, ground
middle is labeled GND, I would assume that also gets grounded (does it matter physical location?)
left is labeled 'S', signal wire from oil pressure or water temp sensor?
right is labeled, 'I', does that mean ignition? I did research a while back and ignition means it receives 12V at KEY ON, but does not receive 12V during cranking?
any help? I can't believe I can't do this I grounded the middle GND to the chassis in the cabin, applied a 12V source to I (which doesn't receive power during cranking), and put the signal wire to S. When I hook up all three like that and turn the key on, the gauge jumps all the way to max (past 100psi). Is this normal? I have not turned the car on yet after this.
