Please Support Morrison Fabrications
Please Support Rix Racing
2G Need help compiling parts list {suspension}
miliman13
1,957
276
Jan 1, 2011
tampa, Florida
So this is what i am ordering : its for the rear .
https://www.amazon.com/dp/B009DJR2U...TF8&colid=3EHB3DWUFD6C1&coliid=I2IHWPKONY2IPT
https://www.amazon.com/dp/B000NSJA1...UTF8&colid=3EHB3DWUFD6C1&coliid=IJ7FGGZH9L6S5
This is a couple things recommended , but i dont know if im supposed to replace it as well.
https://www.amazon.com/KYB-SB108-St...rd_wg=YSmB0&psc=1&refRID=H0NYAAEK9GG064N4RHPD
https://www.amazon.com/dp/B000QPZJUK/ref=wl_mb_recs_8_title
https://www.amazon.com/dp/B000C40TLE/ref=wl_mb_recs_5_title
What i would really like, is something like this: but cant find any for the GSX 2G
https://www.amazon.com/Complete-Ass...rd_wg=6MPNO&psc=1&refRID=ZV026A8GH5A8HWXT8RKP
So my question is What do i really need, what dont i need. and is there such thing as a complete kit like the above link for the 2G Gsx?
Thank you.
I just did struts on my talon. I replaced the upper insulators, top hats (mine were rusty), dust boots, bump stops, upper/lower bushings, and the struts themselves of course.
I used that kyb dust boot bump stop combo you linked in the rear, Moog rear upper insulators, and Prothane bushings. The front bump stops, dust boots, and insulators I got OEM. You can get a bushing kit from rock auto for cheap that will have the upper/lower bushings and the little metal sleeve they ride on. I bought them just for those sleeves. Can't comment on what to do for replacement springs, I just used eibachs.
It's a pretty straightforward job just putting them together yourself. If you are using factory height springs, you will need a spring compressor though.
If you want part numbers for anything I mentioned, I have them in my records.
If it's not to much trouble, that would be helpful.
I've read that the Sebring shares the same suspension as the eclipse.
With two differences, the spring rates are softer but the socks are stiffer too on the Sebring .
I wonder if they will bolt right in...
I'll get em when I get off work.
Alot of suspension parts are interchangeable, but the AWD has different spring rates and valving than the fwd and probably the Sebring.
KYB dust boot/bump stops (these are sort of universal but work fine)- sb103
Moog rear insulators- k7476
Gabriel strut mount kit (includes upper/lower bushings and sleeves)- 142419
Mitsu front spring insulators- MB864798
Mitsu front dust boot- MB864911
Mitsu bump stops (should be the same front/rear, but the label says rear)- MB949043
Mitsu rear dust boots- MB864787
I think that's about it, let me know if I forgot something.
Do you have 3g parts on your car? If so, I was unaware...
No 3G parts on the car.
Were you suggesting that the kit fits a 3G and therefore fits my 2G ?
Alot of the 3g suspension parts will work on a 2g. I couldn't tell you which ones though.
Correct i have read threads were people "repeat" this info, yet to see it being implemented.
^ In relation to the above "quote"
Yes just by looking i believe the complete kit will bolt up to the GSX, however i'm skeptical that it will be A1.
Spring and Shock rating and blah blah.....ect.
Even Amazon says it wont fit....... like the site has ever been right. LOL.
I really want a complete kit, just eye balling the numbers i don't want to piece it together.
Coilovers will be complete.LOL
I know 3g rear lower control arms, end links, and sway bars can be fitted to a 2g. The strut assemblies look similar, but yeah, they almost certainly won't be the right valving and spring rate. Maybe even different lengths. Either way I'd definitely get struts and springs that are 2g AWD specific.
