ShockDSM
- 85
- 9
- Dec 31, 2015
Dearborn,
Michigan
Hey everybody, I'm looking for a local DSM'er to give me a hand with some tasks I've got ahead of me. I've really been treating this old car good as it was left sitting for a few years and needed lots of love. I've got a leaking transfer case on my 1990 GSX and could use a hand at replacing the seals and sealing/replacing the yoke if someone has done it before and wants to come by and help one evening or Sunday, I'll feed you with delicious meats and cheeses and dough, ranch AND marinara, and return the favor!
I also have a clutch that feels as though it's slipping and I believe it might be the rear main seal leaking onto the flywheel. If we could check that out and verify I would like to do the rear main job also, not necessarily at the same time.
I ALSO have a brand new timing belt kit from STM (Mitsu pulleys, Mitsu timing tensioner, and balance shaft belt, kevlar gates racing T belt and waterpump) that I would like to put on the car with someone that has done a timing belt and waterpump job on a 1g with the motor in the car. Also got the timing belt toolkit from STM to help with the install, and can use to do timing belt job on your car if you need it!
My name is Rob, 313.701.4959 texting is fine
I have a heated garage. Don't have all the space in the garage I would like, but it is the only vehicle in the garage and there is room to work. I have a great jack, jackstands, and lots of tools/small air compressor If any special tools are required and you have them, if you could bring them that would be great!
I am located in Dearborn Michigan, at Cherry Hill and Outer Drive. Zip is 48124
pics are when I got the car and how it looks now a month later after some serious TLC.
