bcrosby
- 75
- 0
- Jul 11, 2002
Des_Moines_Iowa
What would make my heater not blow hot? Now that its getting cold out ive noticed that my heater just doesnt blow hot. Could it be the thermostat? Any ideas would be appriciated.
Note: This feature currently requires accessing the site using the built-in Safari browser.
The most common causes are low coolant or missing/stuck/too low temperature thermostat.
Yes if your temp guage is normal, this is an excellent idea.I have similar problems with another car in the past. The heater core could be clogged. After topping off your coolant you could check to see if both the hoses (in and out) of the firewall leading to the heater core are hot.
